encryptions
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
data
The encryption key contents
Type: array of string
datamax
The size of the data array.
Type: integer
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
FU_Option
Differentiates the type of encryption key.
true - /KEY/%FUnn. Used for encrypting function cards, where nn is a key digit varied from 01-99.
false - /KEY/%RDnn. Used for encrypting mats/props, where nn is a key digit varied from 01-99.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
KeydigitsRD
The key digits for /KEY for Radioss from 1-99.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
Version History
2020 - Added new data name color_rgb.
