freebodygroups
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- fbdlist
- The IDs of the FBD entities.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- intersectentityids
- The IDs of the intersect entities.
- intersectentitytype
- The type of the intersect entities.
- name
- The name of the entity.
- orientationvector
- The orientation vector coordiates when systemdef is 2.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- system
- The ID of the system entity when systemdef is 1.
- systemdef
- The system definition type:
Version History
2019.1
2020 - Added new data names color_rgb, orientationvector and systemdef. The resolve data name has been removed and replaced by the systemdef data name. The behavior of the system data name is now dependent on the systemdef data name.
