freebodysections
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- elemidlist
- The element ID list.
- entityids
- The entity ID list.
- entitytype
- The type of the entity.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- name
- The name of the entity.
- nodeidlist
- The node ID list.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- resolve
- Resolve in the chosen system type:
- system
- The system ID when resolve is 2.
- summationpoint
- The symmation coordinates when summationpointtype is 2.
- summationpointtype
- The symmation location:
- summationnode
- The symmation node ID when summationpointtype is 1.
Version History
2019.1
2020 - Added new data names color_rgb and elemidlist.
