hourglass
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
bulkViscosity
The bulk viscosity type. Type: integer
coeff
The hourglass coefficient. Type: double
coeffShellBending
The hourglass coefficient for shell bending. Type: double
coeffShellViscosity
The hourglass coefficient for shell warping. Type: double
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
101 - LS-DYNA *HOURGLASS
controlType
The hourglass control type. Type: integer
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
hgscalefactor
The scale factor for hourglass control forces.
Default is 0.1 for hgtype=1, (Real > 0.0).
Default is 0.05 for hgtype=2, (Real > 0.0).
Type: double
hgtype
1 - Flanagan-Belytschko viscous form
2 - Puso enhanced assumed strain stiffness form for eight nodes CHEXA elements (default)
Type: integer
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
linearBulkViscosity
The linear bulk viscosity coefficient. Type: double
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
quadBulkViscosity
The quadratic bulk viscosity coefficient. Type: double
title
The hourglass title option. Type: Boolean
viscosityDampCoeff
The viscosity damping coefficient for types 6 and 7 hourglass control. Type: double
Version History
2017.1
2019.1 - Added new data names hgscalefactor and hgtype.
2020 - Added new data name color_rgb.
