interfacelinkings
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
config
The configuration of the entity.
101 - LS-DYNA *INTERFACE_LINKING_DISCRETE_NODE_<OPTION>
102 - LS-DYNA *INTERFACE_LINKING_EDGE
103 - LS-DYNA *INTERFACE_LINKING_SEGMENT
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
entityid
The node ID or node set ID to be moved by the interface file. This is supported for config 101 and 102.
Type: entity
filename
The name of the file where the component data will be writen when config=104.
Type: string
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
interfaceid
The interface ID in the interface file. This is supported for config 101 and 102.
Type: integer array
interfaceidlist
The list of interface IDs in the interface file. This is supported for config 103.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
segmentids
The segment sets to be moved by the interface file. This is supported for config 103.
Type: entity array
segmentidsmax
The maximum number of segments referred.
Version History
2019
2019.1 - Added new data name filename.
2020 - Added new data name color_rgb.
