loadsteps
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- cardimage
- The name of the assigned card image.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- contactgroups_ids
- Pointer to the contact groups in the loadstep.
- contactgroups_idsmax
- The number of contact roups in the loadstep.
- definedentity
- True if the entity is defined, false otherwise.
- groups_ids
- Pointer to the groups in the loadstep.
- groups_idsmax
- The number of groups in the loadstep.
- id
- The ID of the entity.
- ids
- Pointer to the loadcols in the loadstep.
- idsmax
- The number of loadcols in the loadstep.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- loadcollector
- Pointer to the loadcollector.
- name
- The name of the entity.
- ob_ids
- Pointer to the outputblock in the loadstep.
- ob_idsmax
- The number of outputblocks in the loadstep.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
Version History
2020 - Added new data names color_rgb. contactgroups_ids and contactgroups_idsmax.
