mbjoints
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- cardimage
- The name of the assigned card image.
- cardimagetype
- The type of the assigned card image.
- childmultibody
- A pointer to the child multibody assigned to the joint.
- childmultibodyid
- The ID of the child multibody assigned to the joint.
- childsystem
- A pointer to the child system assigned to the joint.
- childsystemid
- The ID of the child system assigned to the joint.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- multibody
- A pointer to the owning multibody.
- multibody1id
- The ID of the parent multibody.
- multibody2id
- The ID of the child multibody.
- multibodyid
- The ID of the owning multibody.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- parentmultibody
- A pointer to the parent multibody assigned to the joint.
- parentmultibodyid
- The ID of the parent multibody assigned to the joint.
- parentsystem
- A pointer to the parent system assigned to the joint.
- system1
- The ID of the parent coordinate system.
- system2
- The ID of the child coordinate system
- type
- The solver dependent type code for the entity.
Version History
2020 - Added new data name color_rgb.
