morphvolumes
Unless otherwise specified, data names are accessible in level 3 only.
- aid
- The internal ID of the morph volume.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- edgeids
- The internal IDs of the twelve edges of the entity. Valid for hm_getvalue query only.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- nodeids
- The IDs of the eight corner nodes of the entity. Valid for hm_getvalue query only.
Version History
2020 - Added new data name color_rgb.
