plies
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- cardimage
- The name of the assigned card image.
- cardimagetype
- The type of the assigned card image.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- entitylist
- Pointer to the entity IDs the ply is based on.
- entitylistdisplayed
- entitylistmax
- The number of entities the ply is based on.
- entitytype
- The type of entity ID the ply is based on.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- integrationpoints
- The number of integration points for the ply.
- internalid
- linelist
- Pointer to the line IDs the ply is based on.
- linelistmax
- The number of lines the ply is based on.
- material
- Pointer to the material assigned to the ply.
- materialid
- The ID of the material assigned to the ply. This could be a valid material ID or unresolved material ID.
- name
- The name of the entity.
- node
- Pointer to the drape seed node ID.
- nodeid
- The drape seed node ID.
- orientangle
- The orientation angle of the ply.
- orientangle2
- The orientation 2 angle of the ply.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- resultrequest
- The result request value 0/1.
- surfacelist
- Pointer to the surface IDs the ply is based on.
- surfacelistmax
- The number of surfaces the ply is based on.
- system
- Pointer to the ply system ID.
- systemid
- The ply system ID.
- table
- Pointer to the ply table ID.
- tableid
- The ply table ID.
- thickness1
- The value of thickness.
- thickness2
- The value of thickness2.
- thickness3
- The value of thickness3.
- thickness4
- The value of thickness4.
- type
- The solver dependent type code for the entity.
Version History
2020 - Added new data name color_rgb.
