positions
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
applied
1 if the position is applied, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
config
The configuration of the entity.
1 - Pair list
2 - Body list
3 - Entity list field
101 - LS-DYNA *DEFINE_TRANSFORMATION and *NODE_TRANSFORM
201 - Set or submodel
401 - PAM-CRASH IMPORT
402 - PAM-CRASH EXPORT
403 - PAM-CRASH IMPFIL
404 - PAM-CRASH PICIMP
405 - PAM-CRASH PICEXP
406 - PAM-CRASH PICK
407 - PAM-CRASH TRSFM
501 - Entity list
dataval
The export data keyword.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
export_string
The export parameter string.
Type: string
exportdatavaluemax
The tabular data support for export data.
htf
The heat treatment coefficient.
Type: double
id
The ID of the entity.
ifile
The flag for the mapping file format.
impfil_fname
The name of the mapping file.
Type: string
impfil_path
The directory path of the mapping file.
Type: string
importname
The name of image part.
Type: string
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
ioutfram
The 2K local frame file format activation.
ipf
The process flag.
iplot
The check file option flag.
mechanism
The parent mechanism of the position.
Type: entity
name
The name of the entity.
Type: string
numberofsourcecontrolmax
The tabular data support for source control.
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
picexp_export_control
The picking export control keyword.
Type: Boolean
picexp_export_control_qualifier
The picking export control definition.
picexp_export_control_switch
Activation/deactivation of the picking export control option.
picexp_export_limit
The export limit definition keyword.
Type: Boolean
picexp_export_point
The export point definition keyword.
Type: Boolean
picexp_exportpoint_qualifier
The definition of the output frequency of the picking file.
picexp_exportpoint_value1
The time value depending on the output frequency type specified by picexp_exportpoint_qualifier.
Type: double
picexp_exportpoint_value2
Type: double
picexp_exportpoint_value3
Type: double
picexp_exportpoint_value4
Type: double
picexp_exportpoint_value5
Type: double
picexp_exportpoint_value6
Type: double
picexp_namepicexp
The name of the root file where the picking database will be stored.
Type: string
picexp_write
The picking export file name keyword.
Type: string
picimp_picmax
The maximum number of picking files to be created.
Type: integer
picimp_read
The picking import file keyword.
Type: string
picimp_sidele
The shift to apply to source element identification numbers.
Type: integer
picimp_sidnod
The shift to apply to source node identification numbers.
Type: integer
picimp_smodule
The source module identification path.
Type: string
picimp_source_control
The user-selected picking control keyword card.
Type: Boolean
picimp_source_control_qualifier
The picking control keyword definition.
picimp_source_control_switch
Activation/deactivation of the picking control option.
picimp_source_module
The keyword for defining the source module where entities will be found.
Type: Boolean
picimp_source_shift_idele
The source elements shift definition keyword.
Type: Boolean
picimp_source_shift_idnod
The source nodes shift definition keyword.
Type: Boolean
picimp_sourcefile
The root file name.
Type: string
pick_mppn
The number of processors used in the previous computation to create restart files having the same pick_name.
Type: integer
pick_name
The restart file name.
Type: string
pick_restartfile
The restart file keyword.
Type: string
pick_time
The picking time keyword.
Type: Boolean
pick_timevalue
The picking time value in the restart file.
Type: double
rdist
The search extension for identification of all image elements which are close to target element.
Type: double
sets
The general entity selection set.
Type: entity
sets_count
The set count.
Type: integer
shellvartype1
The shell variable keyword1 data values.
shellvartype2
The shell variable keyword2 data values.
Shellvartypemax
The tabular data support for the shell variable.
Title
Append _TITLE to *DEFINE_TRANSFORMATION keyword.
Type: Boolean
transformations
The transformation entities the position is/can be applied to.
transformations_count
The number of transformation entities the position is/can be applied to.
Type: integer
vars
The shell variable card keyword.
Type: Boolean
varv
The volume element variable card keyword.
Type: Boolean
volumeeletype1
The volume element variable keyword1 data values.
volumeeletype2
The volume element variable keyword2 data values.
volumeeletypemax
The tabular data support for the volume variable.
Version History
2019 - Added new data names dataval, export_string, exportdatavaluemax, htf, ifile, impfil_fname, impfil_path, importname, ioutfram, ipf, iplot, numberofsourcecontrolmax, picexp_export_limit, picexp_export_point, picexp_exportpoint_qualifier, picexp_exportpoint_value1, picexp_exportpoint_value2, picexp_exportpoint_value3, picexp_exportpoint_value4, picexp_exportpoint_value5, picexp_exportpoint_value6, picexp_namepicexp, picexp_write, picimp_picmax, picimp_read, picimp_sidele, picimp_sidnod, picimp_smodule, picimp_source_control, picimp_source_control_qualifier, picimp_source_control_switch, picimp_source_module, picimp_source_shift_idele, picimp_source_shift_idnod, picimp_sourcefile, pick_mppn, pick_name, pick_restartfile, pick_time, pick_timevalue, rdist, sets, sets_count, shellvartype1, shellvartype2, Shellvartypemax, vars, varv, volumeeletype1, volumeeletype2 and volumeeletypemax.
2019.1 - Added new config values 101 and 407. Added new data names picexp_export_control, picexp_export_control_qualifier, picexp_export_control_switch and Title.
