results
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- combinationfile
- The name and path of the combination file.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- evnEqns
- Used to create envelope equations.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- init
- Initialize and generate the hierarchy for the given modelfile, resultfiles and combinationfile.
- internalid
- LspEqns
- Used to create linear superposition equations.
- model_fileid
- The list of file IDs assigned to modelfile in the same order.
- modelfile
- The name and path of the model file.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- result_fileids
- The list of file IDs assigned to resultfiles in the same order.
- resultfiles
- The names and paths of the result files.
- virtual_fileids
- The list of virtual file IDs of derived subcases from evnEqns and LspEqns.
Version History
2019.1
2020 - Added new data name color_rgb.
