seatbeltcontrolpointss
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
1 - Control point
2 - Slipring
3 - Retractor
4 - Pretensioner
5 - Full mesh slipring
6 - Attachment
14 - Pulley
15 - Anchor pretensioner
16 - Preretractor
17 - Load limiter
controlpointattachment
The ID of the entity attached to the control point.
Type: entity
controlpointattachtype
The entity type ID of the controlpointattachment.
Type: entity
controlpointconstrainednode
The ID of the constrained node entity.
Type: entity
controlpointid
The ID of the node of the control point.
Type: entity
controlpointlocation
The location coordinates of the node of the control point.
Type: triple double
controlpointparent
The IDs of the parent seatbelt entities of the control point.
Type: entity array
controlpointpulleynodes
The IDs of the nodes used in creating the pulley element.
Type: entity array
controlpointretractornodes
The IDs of the nodes used in creating the retractor assembly.
Type: entity array
controlpointstructure
The ID of the component used for wrap around when config 5.
Type: entity
cpfullmeshtype
The type of looping mesh.
0 - Wrap around component
1 - Wrap around a cylinder
cpfullshelllayers
The number of layers to be used for creating the full mesh slipring.
cpfullshelloffset
The gap/offset between component and slipring elements.
Type: double
cpfullshellradius
The radius of the cylinder when cpfullmeshtype is 1.
Type: double
cpfullshellsize
The element size in the full mesh slipring.
Type: double
cpoint_x
The x coordinate of the control point location.
Type: double
cpoint_y
The y coordinate of the control point location.
Type: double
cpoint_z
The z coordinate of the control point location.
Type: double
createfullmeshslipring
Create a full mesh slipring, if true.
Type: Boolean
crosssectiondistance
The distance from the end of the assocaited cross-section.
Type: double
crosssectionend
The end of the associated cross-section.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
deletecontrolpointattachments
Deletes control point attachments, when set to 1.
deletefullmeshslipring
Deletes the full mesh slipring, when set to 1.
deletepretensioner
Deletes the pretensioner/retractor assembly, and takes the parent setbelt ID as input.
deletepulley
Deletes the pulley, and takes the parent seatbelt ID as input.
elementabsorption
The option deciding the percentage of elements to be absorbed.
0 - 50% absorbtion
1 - 100% absorption
fullshellbeginnodes
The ID of the set of nodes at the start of the full mesh slipring.
Type: entity
fullshellcomnodes
The ID of the set of nodes in between the start and end of the full mesh slipring.
Type: entity
fullshellendnodes
The ID of the set of nodes at the end of the full mesh slipring.
Type: entity
fullshellslipringelems
The ID of the set of elements in the full mesh slipring.
Type: entity
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
linkedentity
The IDs of the linked elements, sets, sliprings or retractors for the control point.
Type: entity array
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
retractorelem
The ID of the element defining the retractor, anchor pretensioner or load limiter.
Type: entity
retractorzeroelem
The number of zero size elements at the retractor.
Type: entity
Version History
2020
