sets
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- assembly
- Pointer to the assemblies for sets of assemblies.
- attributesmax
- The number of attributes owned by this entity.
- by
- The increment for an ID range clause of a formula set.
- cardimage
- The name of the assigned card image.
- cardimagetype
- The type of the assigned card image.
- clauseentitytypenames
- The list of clause entity type names for a formula set. Valid for hm_getvalue query only.
- clauseentitytypes
- The list of clause entity types for a formula set. Valid for hm_getvalue query only.
- clauses
- Pointer to the clauses in a formula set.
- clausesmax
- The number of clauses for a formula set.
- clausetype
- Clause type of a specific clauses clause.
- clausetypes
- The list of clause types for a formula set. Valid for hm_getvalue query only.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- component
- Pointer to the components for sets of components.
- definedentity
- True if the entity is defined, false otherwise.
- element
- Pointer to the elements for sets of elements.
- elementids
- The list of elements IDs.
- elements
- The list of elements for segment sets. Valid for hm_getvalue query only.
- end
- The end value for an ID range clause of a formula set.
- exceptids
- The list of except IDs for a specific clause in a formula set. Valid for hm_getvalue query only.
- exceptidsmax
- The number of except IDs for a specific clause in a formula set.
- facecode
- Indicates which face of its element the segment set refers to, 0-5.
- faces
- Pointer to the faces for segment sets.
- facesmax
- The number of faces in the segment set.
- facetype
- The number of nodes in the current face, 1-8.
- id
- The ID of the entity.
- ids
- Pointer to the entity IDs
- idsmax
- The maximum number of IDs.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalids
- Pointer to the entity IDs.
- material
- Pointer to the materials for sets of materials.
- name
- The name of the entity.
- node
- Pointer to the nodes for sets of nodes.
- node1
- The ID of node 1 for the current face. This is reported taking into account whether or not the contact is reversed with respect to the element normal.
- node2
- The ID of node 2 for the current face. This is reported taking into account whether or not the contact is reversed with respect to the element normal.
- node3
- The ID of node 3 for the current face. This is reported taking into account whether or not the contact is reversed with respect to the element normal.
- node4
- The ID of node 4 for the current face. This is reported taking into account whether or not the contact is reversed with respect to the element normal.
- node5
- The ID of node 5 for the current face. This is reported taking into account whether or not the contact is reversed with respect to the element normal.
- node6
- The ID of node 6 for the current face. This is reported taking into account whether or not the contact is reversed with respect to the element normal.
- node7
- The ID of node 7 for the current face. This is reported taking into account whether or not the contact is reversed with respect to the element normal.
- node8
- The ID of node 8 for the current face. This is reported taking into account whether or not the contact is reversed with respect to the element normal.
- nodes
- The IDs of the nodes in the current face.
- ordered
- 0 if non-ordered, 1 if ordered
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- property
- Pointer to the properties for sets of properties.
- remove
- The remove value for an ID range clause of a formula set.
- reversecode
- The with/against normal status of the current face.
- rigidlinkconnected
- Pointer to a rigid link element to which the node set is attached. Returns 0 for non-nodal sets or for sets not attached to rigid links.
- rigidlinkindependentnodeid
- The ID of the independent node of the rigid link element to which the node set is attached. Returns 0 for non-nodal sets or for sets not attached to rigid links.
- set
- Pointer to the sets for sets of sets.
- start
- The start value for an ID range clause of a formula set.
- style
- The style of the entity set.
- support
- The set support type:
- type
- The type of set.
- typename
- The type of set. nodes
Version History
2019.1 - Added new data names draft and draftangle.
2020 - Added new data names color, color_rgb, elements, facecode, faces, facesmax, facetype, node1, node2, node3, node4, node5, node6, node7, node8, nodes, reversecode and support.
