titles
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- anchorangle
- The angle from vertical for the title pointer.
- anchorcorner
- The anchor corner of the title.
- anchorpoint
- attributesmax
- The number of attributes owned by this entity.
- bordercolor
- The color of the border.
- borderon
- 1 if the border is on, 0 otherwise.
- borderwidth
- The width of the border.
- borderxmax
- The maximum x value of the border.
- borderxmin
- The minimum x value of the border.
- borderxpoints
- The min and max x border points. Valid for hm_getvalue query only.
- borderymax
- The maximum y value of the border.
- borderymin
- The minimum y value of the border.
- borderypoints
- The min and max y border points. Valid for hm_getvalue query only.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- distance
- The distance from the entity to the border.
- entity
- The ID of the entity for titles attached to entities.
- entityconnectionangle
- entityid
- fillcolor
- The title fill color, used during H3D export only. Valid values are 1-64.
- font
- The font used, 1-4.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- text
- The title text.
- transparency
- The title transparency, used during H3D export only.
- type
- The type of the entity the title is attached to.
- typename
- The string name of the entity the title is attached to.
Version History
2019 - Added new data names fillcolor and transparency.
2020 - Added new data name color_rgb.
