weldlines
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- Eval_select
- True selected for analysis, false not selected for analysis.
- General_table
- The table ID consisting of the general location details.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- Location_table
- The table ID consisting of the location details for each location point.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- Result_status
- True if damage is <= 0, false if damage > 0.
- Resultvalue
- The damage value.
- Weld_detection
- Indicates whether the weld is shell or solid.
- Weld_part
- The component ID of the 1D elements to set.
- Weld_type
- The type of weld. Valid values are Butt, Cross, L, Multiple, Overlap and T.
- weldlocationentityids
- The table ID consisting of the location entity IDs for each point location.
Version History
2020
