hm_entitylist
Returns a list of names or IDs of all entities of the requested type.
hm_entitylist entity_type name_or_id ?mode?
HyperMesh Tcl Query Command
entity_type
The type of entity to query.
name_or_id
The type of list to generate. Valid values are:
name - Return the list of names. Only named entity types support this option.
id - Return the list of IDs. All entity types support this option.
mode
An optional argument that specifies which entity types are returned:
active - Return only the active entities. This is the default if not specified.
all - Return both active and inactive entities.
inactive - Return only the inactive entities.
To get the list of node IDs:
hm_entitylist nodes id
To get the list of component names:
hm_entitylist comps name
   # Handle error
Version History
2019 - Added new optional mode argument.
