HM_ExtAPI::CreateSurfacePlane()
Creates plane surface object.
bool CreateSurfacePlane(
HM_EntityGeometrySurface& new_plane,
const HM_Point& plane_base,
const HM_Vector& u_axis,
const HM_Vector& v_axis
HyperMesh Ext API Function
The function creates the surface object of the type HM_ExtAPI::PLANE().
The points on the plane surface can be calculated parametrically as
S(U, V) = C + u U + v V
The following table summarizes correspondence of the parameters used in the equation to parameters used by the function CreateSurfacePlane.
Parameters used by CreateSurfacePlane Plane parameters
plane_base C
u_axis u
v_axis v
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
new_plane
[out] - Handle to new surface object.
plane_base
[in] - The point of the plane corresponding to surface parametric point u=0, v=0.
u_axis
[in] - Vector in the plane that defines parametric U axis.
v_axis
[in] - Vector in the plane that defines V axis.
None.
