HM_ExtAPI::CurveCircleGetData()
Returns parameters that define circle.
bool CurveCircleGetData(
const HM_EntityGeometryCurve& curve,
HM_Point& center_point,
HM_Vector& unit_normal,
HM_Vector& radius
HyperMesh Ext API Function
The function expects that the type of curve object is HM_ExtAPI::CIRCLE(). Application should call the function HM_ExtAPI::GeomCurveGetType() to verify the type before calling CurveCircleGetData function.
The points on the circle can be calculated parametrically as
C(t) = C + R cos t + [n X R] sin t
using parameters returned by the CurveCircleGetData function as summarized in the table below.
Parameters used by CurveCircleGetData Circle parameters
center_point C
unit_normal n
radius R
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
curve
[in] - Handle to curve object that was returned by previous calls to API functions.
center_point
[out] - Circle center points.
unit_normal
[out] - Unit length vector normal to the plane that contains the circle.
radius
[out] - Vector from center point to circle point corresponding to zero angle parameter.
None.
