hm_getdirectionpanel
Provides a panel to define a direction/vector.
hm_getdirectionpanel ?message? ?default_value?
HyperMesh Tcl Query Command
Provides a panel to define a direction/vector. A list with three values is returned from this command when successfully executed:
{dir_x dir_y dir_z}
- ?message?
- Optional string to show in the status bar when entering the panel.
- ?default_value?
- Optional default value to set the entity filter to when entering the panel. message must be specified to use this option.
To get a direction definition from a user:
set direction [hm_getdirectionpanel "Please define a direction"]
foreach {dx dy dz} [lindex $plane 0] {}
# Handle error
Version History
12.0.110
2017.1 - Added new optional default_value argument.
