hm_jobs_submitOptistructJob
Submits a OptiStruct job to the server.
hm_jobs_submitOptistructJob version job_name memory cpu input_file output_path additional_files zip_flag args
HyperMesh Tcl Query Command
Returns the job ID upon successful submission, or null on failure.
Always set the current server on which the job needs to be submitted by using hm_jobs_setCurrentServer before submitting a job. To run jobs locally using PBS-sensor, set the current server as "local". Jobs submitted using the local server will run in sequential order. For local job submission, the additional_files and zip_flag arguments can be passed as null strings, and the master file should hold all the information related to the additional files.
app_id
The application name to which the job has to be submitted to (for example, OptiStruct).
version
The OptiStruct version to use (for example, 2020).
job_name
The name of the job to submit.
memory
The memory required for the job to run.
cpu
The number of CPUs to be used.
input_file
The full name and path of the input file.
output_path
The full path where the output should go.
additional_files
A string containing any required additional files that need to be uploaded.
zip_flag
Must be set as "true" if any .zip file is passed, "false" otherwise.
args
Any additional OptiStruct command line arguments.
Examples
To submit a OptiStruct job on the server:
hm_jobs_submitOptistructJob OptiStruct 14.0 "new_job" 1000 2 "C:/temp/input/MASTER.fem" "C:/temp/output" "{C:/temp/input/slave1.fem} {C:/temp/input/slave2.fem}" false "-maxlen 3000"
   # Handle error
Version History
14.0.130
