hm_setpanelposition
Sets the position of the panel area.
hm_setpanelposition position
HyperMesh Tcl GUI Command
This command sets the position (top | bottom) of the panel area. If the panel area is not currently visible, it will not be turned on.
- position
- The position of the panel area. Valid values are top and bottom.
hm_setpanelposition top
# Handle error
Version History
9.0
