HMIN_endsurf()
Signals the end of a surface.
void HMIN_endsurf(void);
HyperMesh hminlib Function
None.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Signals the end of a trimming line.
Signals the start of an object space line.
Signals the start of a parameter space line.
Signals the start of a trimming line.
Signals the beginning of a surface.
Writes a fixed meshing point for a surface.
Specifies the information for a NURBS surface.
Specifies the information for a plane.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
None.
