HMIN_hmxfilename()
Returns the name of the HMX file.
char* HMIN_hmxfilename();
HyperMesh hminlib Function
Returns the name of the generated HMX file.
None.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Saves supplied text to an .hmx file.
Allows you to send a message to the message file while a database is being read in.
Sets the file extension for the unsupported data log file.
Sets the directory where the HMX file is created.
Writes a status message to the menu header bar.
Writes an error message to the menu header bar (in red).
ON THIS PAGE
None.
ON THIS PAGE
