HMIN_mbjoint_write()
Writes multibody joints to HyperMesh.
void HMIN_mbjoint_write (HM_entityidtype id, char *name, unsigned char color, int type, HM_entityidtype multibodyid, HM_entityidtype multibody1id, HM_entityidtype multibody2id, HM_entityidtype system1id, HM_entityidtype system2id);
HyperMesh hminlib Function
id
The ID of the multibody joint.
name
The name of the multibody joint.
color
The color assigned to the multibody joint.
type
The type assigned to the multibody joint.
multibodyid
The ID of the multibody.
multibody1id
The ID of multibody 1 (parent/child).
multibody2id
The ID of multibody 2 (parent/child).
system1id
The ID of system 1 (parent/child).
system2id
The ID of system 2 (parent/child).
None.
