Command Files
The HWC log file contains a record of the HWC Console activity. It can be turned on/off using the Log to File context menu option in the HWC Console.
HWC Command File Location
The default filename for the HWC log file is hw_command.hwc. This file is saved by default to your working directory if you select the Log to File option. Use the environment variable HW_COMMANDFILE_DIR to change the default save location.
- Append
- Any existing command file is appended (default).
- Overwrite
- Any existing command file is overwritten instead of appended.
- Unique
- A new command file is generated with the name hw_command_<timestamp>_<username>.hwc.
