mark sset
Marks entities by selection set.
mark sset <name>
mark sset sset <name>
Arguments
- <name>
- The name of the selection set.
- sset
- Clear by the selection set name.
mark sset sset Set_3.1
mark sset "0D Set"
Use HWC commands in the Tcl Console.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Result loading.
Save session content.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Tracking system commands.
View manipulation.
mark sset <name>
mark sset "0D Set"
