show legends
Shows legends.
show legends
show legends
Use HWC commands in the Tcl Console.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Result loading.
Save session content.
Section cut.
Shows all or a subset of entity types in the model.
Shows all entities in the active model.
Shows components in the active model.
Shows elements in the active model.
Shows legends.
Shows marked entities.
Shows all or parts of a model.
Shows selection sets.
Shows systems.
Shows a tracking system.
Modify entities in a selection set.
Tracking system commands.
View manipulation.
Shows legends.
Shows legends.
show legends
show legends
