sset rename
Renames a selection set.
sset rename <name> <new name>
Arguments
- <name>
- Select the set to rename.
- <new name>
- Enter the new name for the selection set.
sset rename Set_1 Set_2
Use HWC commands in the Tcl Console.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Result loading.
Save session content.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Adds entities to a selection set.
Creates an empty selection set.
Deletes a selection set.
Creates a set with displayed entities.
Exports sets to a file.
Imports a set from a file.
Removes entities from a selection set.
Tracking system commands.
View manipulation.
