ardi::item
ardi::item::apply args
For better performance data created, manipulated or deleted go into a cache. This API processes the cached data, clears the cache and redraws the GUI if needed.
Returns
1 for ok
tcl-error in case of error
ardi::item::delete args
Deletes the item with the specified ID.
-id
value: item ID.
default value: ""
Returns
1 for ok
ardi::item::getpropertyid args
Queries id of property.
-id
value: item ID
-key
value: property key
ardi::item::getpropertykeylist args
Queries list of properties.
-id
value: item ID
Returns
list of property keys for a particular item id.
ardi::item::getroot
Queries the ID of the report root item. This is the top most item.
Returns
ardi::item::gettype args
Queries the type of the item with the specified ID.
-id
value: item ID.
default value: ""
Returns
the type of the item.
ardi::item::gettypelist
Queries available types of items.
Returns
a list of item types.
