ardi::item::table
Interact with items of type table.
Supported property names are: -name -value -parent -type (read only) -numberofrows -numberofcolumns -showcolumnheader -showrowheader. All properties available can be passed via the "create" API or modified on an existing item via the "set" API.
ardi::item::table::create args
Creates an item of type "table".
For a full list of property names, see above.
Returns
The ID of the item or tcl-error in case an error occurred during creation. i.e ardi::api::item::table create -name "My Table Item"
ardi::item::table::delete args
Deletes the item with the specified ID.
-id (mandatory)
value: item ID. The item ID which is returned by the corresponding "create" API.
default value: ""
Returns
1 for ok
tcl-error in case of error i.e ardi::api::item::table delete -id $id
ardi::item::table::get args
Queries the value of one property.
-id (mandatory)
default value: ""
Returns
The value of the specified property or tcl-error in case of error usage: ardi::item::table get -id $id -property parent
ardi::item::table::getcell args
Queries the value on a cell identified by row and column ID. Row and column IDs start with 0.
-id (mandatory)
default value: ""
-row (mandatory)
value: row ID. The ID of the row.
default value: ""
-column (mandatory)
value: column ID. The ID of the column.
default value: ""
Returns
the value of the cell, tcl-error in case of error i.e ardi::api::item::table getcell -id $id -row 0 -column 0
ardi::item::table::getheader args
Queries the header text on a row or on a column. Row and column IDs start with 1. Specify either row or column ID to query the current value.
-id (mandatory)
default value: ""
-row
value: row ID. The ID of the row you want to query the header text.
default value: ""
-column
value: column ID. The ID of the column you want to query the header text.
default value: ""
Returns
the header text
tcl-error in case of error i.e ardi::api::item::table getheader -id $id -column 1
ardi::item::table::getpropertyid args
Queries id of property.
-id
value: item ID
-key
value: property key
ardi::item::table::getpropertykeylist args
Queries list of properties.
-id
value: item ID
Returns
list of property keys for a particular item ID
ardi::item::table::set args
Sets one or multiple parameters to specified values. The type of the item is assigned upon creation and cannot be changed after.
-id (mandatory)
default value: ""
Returns
1 for ok
tcl-error in case of error i.e ardi::api::item::table set -id $id -name "My Table Item" -value "Good morning, how are you today?"
ardi::item::table::setcell args
Sets the value on a cell identified by row and column ID. Row and column IDs start with 0.
-id (mandatory)
default value: ""
-row (mandatory)
default value: ""
-column (mandatory)
default value: ""
-value
value: The value you want to set on the cell.
Returns
1 for ok
tcl-error in case of error i.e ardi::api::item::table setcell -id $id -column 1 -value "My Header Text on column 1"
ardi::item::table::setheader args
Sets the header text on a row or on a column. Row and column IDs start with 0. Specify either row or column ID to set the header text to desired value.
-id (mandatory)
default value: ""
-row
value: row ID. The ID of the row you want to set a particular header text.
default value: ""
-column
value: column ID. The ID of the column you want to set a particular header text.
default value: ""
-value
value: The text you want to set as header of the spcified row or column ID.
Returns
1 for ok
tcl-error in case of error i.e ardi::api::item::table setheader -id $id -column 1 -value "My Header Text on column 1"
