hwIAVIExportOptions SetFrameRate
Sets the frame rate used when exporting AVI files.
hwIAVIExportOptions_handle SetFrameRate value
HyperWorks Tcl Modify
This parameter is used when exporting AVI files from either the video or animation clients during HTML export.
value
The frame rate (frames per second) to be used when exporting AVI files.
To set the current value of the frame rate used when exporting AVI files:
mySessionName GetAVIExportOptionsHandle myAviOptions
myAviOptions SetFrameRate 25.0
Error
Success (0) or an error code (see below).
HW_InvalidHandle
The handle used to invoke the method is no longer valid.
HW_InvalidArgs
The value for the frame rate is out of the valid range (must be greater than 0).
