hwISession RegisterExternalReader
Registers the given external reader.
hwISession_handle RegisterExternalReader filename, type, ext, category
HyperWorks Tcl Query
filename
The name of the reader to be registered.
type (Optional)
The type of the reader to be registered. This string, if specified, appears in the drop-down combo box of the File dialog.
ext (Optional)
If specified, this is the extension actually used as a filter if the specified type is chosen in the File dialog.
category (Optional)
The category of the reader to be registered. Options include “asc” (ASCII), “bin” (binary), or left unspecified for a generic category (which is the default).
mySessionName RegisterExternalReader myReader “New External Reader (*.new)”  *.NEW asc
Error
Success (0) or an error code.
