SetHiddenSet
Sets the set to be used for hiding entities.
bestview_handle SetHiddenSet loc_string
HyperView Tcl Modify
This command sets the set to be used for hiding entities. Any entities in the specified set will be hidden in the view. This will make sure that the given set of entities is not shown for the current best view.
Important: This setting is applicable to only following best view modes: global, globallocation, contour, and transparency.
Other modes of best view will ignore the hidden set settings.
loc_string
A string to locate the set, typically a pool/ID combination (example: {User_Set 1}).
To set the set to be used for hiding entities in the best view:
bestview_handle SetHiddenSet {User_Set 5}
Returns success (0) or an error code.
