poICollisionCtrl Reset
Clears all collision sets.
poICollisionCtrl_handle Reset
HyperView Tcl Modify
This command clears all collision sets.
Error
Returns 0 if successful, otherwise an error code.
Adds a collision set to be used by the collision control.
Gets the active collision control set.
Gets a handle to the collision set by ID.
Gets a collision set list.
Gets an auto load/unload collision data state.
Gets the legend control object for vector control.
Removes the collision set.
Sets the active collision set value.
Sets the auto load/unload collision data state.
Writes out the summary for the collision detection.
