poICollisionSet SetProximity
Sets the proximity value.
poICollisionSet_handle SetProximity
HyperView Tcl Modify
This command sets the proximity value.
Error
Returns 0 if successful, otherwise an error code.
Adds selected entities to be used by the collision control.
Returns the event which triggers animation stop.
Returns the binding: part, element, or node.
Returns the proximity state.
Returns the collision set ID.
Returns the collision set label.
Returns the proximity value.
Returns a selection list for a given group.
Removes the selected entities.
Clears all selection sets.
Sets the event which triggers animation stop.
Sets the binding: part, element, or node.
Sets the proximity state.
Sets the collision set label.
