poIComponent GetColor
Gets the component color index.
poIComponent_handle GetColor list
HyperView Tcl Query
This command returns the component color index.
None.
Sets component material to default values.
Gets the assembly ID of a component.
Gets the component auto color index.
Gets a list of the all child components.
Gets the component's ID.
Gets the component display option setting.
Gets a list of component display modes.
Gets the component's label.
Gets the component's material index.
Gets the component’s mesh mode.
Gets the number of child components.
Gets the component's polygon mode.
Gets the component's tracing mode.
Gets the translation vector in the global coordinate system.
Gets the component's type string.
Gets the component’s visibility.
Sets the assembly ID of a component.
Sets the component’s auto color index.
Sets the component’s color index.
Sets the component's display mode.
Sets the component’s label.
Sets the component's material index.
Sets the component’s mesh mode.
Sets the component’s polygon mode.
Sets the component’s tracing mode.
Translates a component by the vector given.
Sets the component’s visibility.
HyperView Tcl Query
None.
