poILayerFilter GetSubcase
Gets the subcase ID with which the layer filter has been created.
poILayerFilter_handle GetSubcase
HyperView Tcl Query
This command returns the subcase ID with which the layer filter has been created.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle CreateLayerFilter 1 “Composite Stress” 2
result_handle GetLayerFilterHandle filter_handle 1
set sub_id [filter_handle GetSubcase]
hwi CloseStack
Returns zero if the layer filter controller handle is invalid.
