Create Reports
Use the Report tool, formerly known as Automated Reporting Director, to create and export Word and PowerPoint Presentation (PPT) reports from within the HyperWorks session. These reports can be used to interpret and analyze simulation results.
Reports can be used to generate, exchange, and present simulation reports internally or externally. It is precisely tailored to capture the best practices of the report generation process and is independent of industry and product type. It has been proved to be invaluable to analyze the simulation results such as stress, fatigue, and vibration.
- Create new Word or PPT reports from scratch based on the company master document. Additionally, save the report template if required. You can also export a PDF version of the report session format.
- Create standardized reports by loading a pre-defined report template.
- Create reports both in interactive view and in batch mode.
Report Output Formats
- Word Reports
- Consist of a summary of the process or a full report. With the report building elements, similar to the Microsoft Office Word, you can build and export Word reports ranging from a few to hundreds of pages.
- PowerPoint Reports
- Consists of a few slides to a few hundred slides.
Minimum Software Requirements
Software | Minimum Version |
Operating Systems |
Office Versions |
.NET Frameworks |
