Create Word Reports
Follow these steps to create Word reports using the Report tool.
To create a Word report, use the Word Report Items, which are accessible from the right-click context menu in the Report Browser.
- From the menu bar, select File > Publish > Report.
- Select the Word Master file using New > Word.
In the Select master document dialog, select the required
Word master file.
Figure 1. - Add entities.
- Add modules.
Execute the report.
Once the report tree is created, execute the items that query and extract data from the HyperWorks session.
Check the boxes under the Export
column for all items.
Click Execute
All items marked for execution are executed, and the output and previews are generated. Once the tree is executed successfully, you can check the previews of the Image, Table, and Results table items. -
Export report.
After the execution, export the report to your chosen location.
Click Export Report
In the dialog, browse to the destination folder, enter the name for the
report file, and click Save.
This saves the Word report in the folder, along with a report template .tpl file.Note: The saved report template is discussed further in Save and Re-use Report Templates.
While the report is being exported, the Word report file launches automatically and the content is inserted dynamically. Once the report is exported, a success message is displayed in the HyperWorks status bar in the bottom-left window. -
