Modal Analysis Summary
Add a summary of the modal analysis as a table to the report.
- Right-click at the Report or Chapter level and select Restriction: This module is available for HyperView only.
- Below are the properties associated with Modal Analysis Summary module.
- Name: Provide the name for the Modal Analysis Summary
module.
Basic Options
- Model: Select the required HyperView page or window of the session.
- Load Cases: Select the load cases to be used for looping. By
default, Active is selected.
Advanced options
- Define Precision: A numerical value to define the precision for the modal frequencies.
- Define Threshold: Define the threshold values for the modal frequenices.
- Auto Split Table: Provides the function to split up tables automatically based on the space available in the slide or page.
module.
