Load Existing Tasks
To load a task, on the toolbar, click
- From the Select Task File dialog that opens, select a task file, for example, MathTask.tsk.
Select Open, and the task appears on your screen.
The loaded task includes the default values for variables as defined in the .tsk file. If you are using a user-defined data type, then an empty object of the defined type is created.
