Use the Parameters Browser to parameterize the contents of a session file or report template and automate a variety of analysis processes with
the Parameters Browser.
Use the Process Manager to rapidly develop and deploy process automation applications for standard product engineering practices within the
HyperWorks environment using the Process Manager.
Learn how the Task Builder helps you to create new tasks, data types, and processes, and save them inside of catalogs
that are easily accessible from the Task and Process browsers.
During an Automate session, you can save your work in progress, and at any given time reload the session and resume
working from the exact point where you left off.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
Before you begin, complete
the steps in Run Math Tasks, and then drag and drop two
more MathTasks into the Process Modeling window.
Connect the blocks: Click the output port of the first block, and then click
the input port of the second block.
A blue highlighted line appears after you click one port and then move
toward the next port. Once you click the second port, the blue line turns black
letting you know that the blocks are connected.
Connect the second and third block.
Your process should look something like this:
On the toolbar, click to
execute the math process.
In the command window, verify the values for each of
the three tasks:
