Create Gauge Inputs
Use the Gauge tool to create design variables based on the thickness of selected properties.
Do one of the following:
- From the Design Explorer ribbon, Inputs tools, click the
Gauge tool.Figure 1.
- Click the Gauge tool satellite icon
. In the Inputs dialog, Details tab, click
Gauge tool.
Select properties in the graphics area or by using the Advanced
Selection dialog.
Gauge input values can be entered in one of the following ways:
- As a continuous range of values, where the lower and upper bounds are specified as a percentage plus or minus its nominal value.
- As a continuous range of values, where the lower and upper bounds are specified specifically.
- As a list of discrete values.
In the microdialog,
- Select how you would like to define the input values, then either specify the lower and upper bounds or specify a list of valid discrete values.
Click Create.
The input is added to the Design Explorer Browser.
