Scatter Plot
Plot exploration inputs and outputs.
Scatter Plot is not available for Optimization explorations.
  1. From the Design Explorer ribbon, Evaluate tool group, click the Results Explorer tool.
    The Results Explorer browser opens.
  2. In the Results Explorer browser, click the Scatter Plot icon .
    The Scatter Plot window opens.
  3. In the Scatter Plot window, select the desired X-axis value and the desired Y-axis value(s).
  4. Analyze the plot.
    Each point in the plot corresponds to an individual run in the DOE.
    Tip: Creating constraints for DOE explorations can be useful, as they can be selected and plotted as datum lines on a scatter plot. This can be a good visualization tool to see which runs in the DOE violate constraints and which are potentially feasible designs.
