Trade Off
Predict response values resulting from different design variable choices.
Trade off is not available for Optimization explorations.
View new features for HyperWorks 2020.
An exploration is a multi-run simulation. Each exploration includes input design variables, and output responses. Explorations may also include goals, consisting of an objective and constraints. Optimization explorations require an objective.
An input design variable is a system parameter that influences the system performance in the chosen output response. Typical design variables may be a part's thickness, shape, or material property. Ranges, with lower and upper bounds, are specified and the variable's value will vary within the exploration. The terms input, input design variable, and design variable are used interchangeably.
An output response is a measurement of system performances, such as mass, volume, displacement, stress, strain, or reaction forces.
Objectives are metrics to be minimized or maximized in an optimization exploration. Minimizing mass to find a lightweight design is a common example.
Constraints need to be satisfied for an optimization to be acceptable. Constraints may also be associated with a DOE. While not used in the evaluation of the DOE, constraints can be useful while visualizing DOE results. Limits on displacement or stress are common examples.
Use the Evaluate tools to run the exploration and review reports.
Export files to the output directory then run the exploration simulations.
Stop a simulation and cancel any runs that are pending or in progress.
Use the Results Explorer tool to review results.
The Results Explorer is an integrated tool which allows users to review and visualize the results of their explorations. The Results Explorer presents different options depending on the type of exploration being reviewed.
Visualize contours for each run in the modeling window.
Once an exploration is complete, review a summary of design variable and output response values in tabular format.
Visualize the relative effects that design variables and output responses have on DOE explorations.
Plot exploration inputs and outputs.
Plot a 2D chart of the input variable and output response values for each run in an Optimization exploration.
Plot the iteration history of an Optimization exploration's objectives, constraints, input variables and unused output responses in a 2D chart.
Examples show how to use the design explorer.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
