Load Command Files, Scripts, and Solver Templates
Playback commands, run scripts, or load a custom solver template to automate your workflow.
  1. From the menu bar, go to File > Load and select whether to load a command file (*.cmf), Tcl/Tk Script script (*.tcl, *.tbc), or solver template.
  2. In the dialog, select the file to open.
For more information, see the HyperMesh Reference Guide.
