Springs Panel
Use the Springs panel to create spring elements.
A spring element is an element created in a space between two nodes of a model where a spring connection is desired. In Radioss, three noded or four noded springs can be created.
Spring elements store a property and a degree of freedom (DOF).
Spring elements are element config 21 and are displayed as a line between two nodes with the letter K written at the centroid of the element.
Springs can translate to CELAS2 in Nastran or *SPRING in Abaqus.
Create Subpanel
Option | Action |
node 1 |
Select the first end of the spring element.
![]() Figure 1. |
node 2 |
Select end b of the spring element.
Note: Once you select
both end a and end b, HyperWorks creates the spring
element.
![]() Figure 2. |
no vector / orient vector |
dof1 - dof6 | Select the degree of freedom (DOF) that applies to the element. |
property | Select a property to which the entity should point. |
Update Subpanel
Option | Action |
node 1 |
![]() Figure 3. |
node 2 |
element.
![]() Figure 4. |
Spring2, Spring3, Spring4 Subpanel
Option | Action |
node | Select the nodes to
create spring elements between. In the Spring3 subpanel, use the third node selector to select the direction node. |
orientation | Choose a method for
orienting springs in 3D space.
Command Buttons
Option | Action |
reject | Revert the most recent change. |
review | After each spring is
selected, HyperWorks indicates which degree of
freedom (dof1 through dof6) is active for the element, and also
displays the appropriate values after property = . This function assumes the spring element is active and on the screen. To make a spring element with the same degree of freedom as an existing one, review the existing element. This places the appropriate degree of freedom and property into the panel. |
update | Implement the changes made in the panel. |
return | Exit the panel. |
