Plots Panel
Use the Plots panel to create and manage plot collectors.
![]() Figure 1. Standard Plot |
![]() Figure 2. Dual Plot |
Panel Options
Option | Action |
plot = | Specify a name for the plot collector. |
like = | Click to select an existing plot whose default values you want to use for the new plot. |
standard / real/imag / phase/mag | Select a method for
creating plots.
Note: After you create a real/imag or phase/mag plot, the
standard selection is removed from the menu.
Command Buttons
Button | Action |
create plot | Create a new plot based on the current inputs. |
select curves | Select the curves to
display. After you click return, the
curves you selected are displayed in the plot.
![]() Figure 3. |
return | Exit the panel. |
