Read Curves Panel
Use the Read Curves panel to read in an xy data set from an ASCII file. As a result, an xy curve is created that represents that data graphically.
Panel Options
Option | Action |
plot = | Select the plot on which you want to display the new curve. |
file: | Double click file = to open a file browser and select the file that contains the xy data. |
Command Buttons
Button | Action |
input | Load the specified
curve data and create a curve from it. ![]() Figure 1. Initial Plot, No Curves ![]() Figure 2. Initial Plot After a Curve is Read In |
return | Exit the panel. |
