Midmesh Panel
Use the Midmesh Panel to automatically generate a mesh at the midplane location, directly from the input geometry (components, elements, solids or surfaces), without first creating a midsurface.
Create Subpanel
- entity selector
- Select the source used to create the midmesh.
- Destination component
- Select which component newly created midmeshes are placed in.
- Ignore flat edges
- Do not imprint flat edges from the input geometry onto the
midmesh.
Figure 1. Option Off
Figure 2. Option On - Flatten connections
- Aligns/flattens the midmesh at ribs/connections.
Figure 3. Option Off
Figure 4. Option On - Edit criteria
- Set the minimum size and target element size settings in the criteria file to control the resulting midmesh via the Criteria File Editor.
- Extraction size
- The midmesh extraction size. By default, this is taken as the target element size from the criteria file. This can be set smaller than the target size, though that is not recommended unless there are problems extracting at the target size.
- Minimum size
- Minimum element size allowed in the finalized mesh. This in combination
with the ‘suppress proximity edges factor’ and 'combine non-manifold
edges factor’ can ensure that the output mesh is ready for rebuild with
the same criteria.
Can only be modified in the Criteria File Editor.
- Suppress proximity edges factor
- The minimum size factor for removing edges within proximity. Edges
closer than this factor times minimum size will be
suppressed.
Figure 5. Option Off
Figure 6. Option On - Combine non-manifold edges factor
- The minimum size factor for joining non-manifold edges. Non-manifold
edges closer than this factor times minimum size will be
combined.
Figure 7. Option Off
Figure 8. Option On - Defeature openings with width <
- The maximum width for removal of small holes and openings.
Figure 9. Option Off
Figure 10. Option On - rebuild mesh...
- Opens the Rebuild Mesh Panel.
- thickness map...
- Opens the Map Midmesh Thickness dialog.
- comparison...
- Opens the Comparison Tool dialog.
Edit Edge Subpanel
- create mid-edge
- Create a new mid-edge, optionally using the input geometry as a
guide:
Figure 11. Before
Figure 12. Without Guides
Figure 13. With Guides
- split by two nodes
- Create a new edge between two nodes.
Figure 14. Before
Figure 15. After - split by node-edge
- Create a new edge between a node and an edge, using a shortest,
tangential or mixed path.
Figure 16. Before
Figure 17. Shortest Path
Figure 18. Tangential PathFigure 19. Mixed Path
- delete edge
- Delete an edge.
Figure 20. Before
Figure 21. After - t-edge align
- Align/flatten a t-connection edge to a surface.
Figure 22. Before
Figure 23. After - by geom edge
- Align mesh edges to input geometry lines and smooth the
mesh:
Figure 24. Before Align
Figure 25. After Align - replace node
- Opens the Replace Panel.
- edit element
- Opens the Edit Element Panel.
- edges
- Opens the Edges Panel.
- delete
- Opens the Delete Panel.
- align nodes
- Opens the Node Edit panel, align node subpanel.
- project
- Opens the Project Panel.
- rebuild mesh...
- thickness map...
- comparison...
Edit Face Subpanel
- fill face
- Create a mesh within a closed 1D topology loop, attempting to keep
tangency. Optionally, the 1D loop can be deleted, keeping only free and
non-manifold edges.
Figure 28. Before
Figure 29. After - repair face
- Attempt to fix topological problems (holes/gaps/cracks, intersections,
slivers, overlaps) in the mesh and remesh the face.
Figure 30. Before
Figure 31. After - detect intersections
- Detect intersecting element clusters and holes/gaps/cracks, and create
element sets for further handling.
Figure 32. BeforeFigure 33. After
- align face
- Align a selection of elements to an input geometry surface:
Figure 34. Before
Figure 35. After
- replace node
- edit element
- delete
- project
- rebuild mesh...
- thickness map...
- comparison...
